path: root/c/src/exec/score/inline (follow)
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-192-0/+372
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-1132-454/+516
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-288-20/+46
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-232-12/+46
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-232-76/+14
* Merged PowerPC port as submitted by Andy Bray of I-CUBED, LtdJoel Sherrill1995-08-222-2/+2
| | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language.
* + Added object type field to object id.Joel Sherrill1995-08-182-10/+48
| | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control.
* bug fixes to make macro implementations workJoel Sherrill1995-08-162-42/+2
* Fully tested on all in-house targetsJoel Sherrill1995-05-242-70/+0
* Initial revisionJoel Sherrill1995-05-1136-0/+5388
