To achieve this:
been removed.
automake:
* I didn't yet touch the cpu subdirectory. I still need some time to
think on how to handle them.
* I probably will wait for the next snapshot before mailing more patches
(I still have some pending), giving you a chance to apply them and me a
chance to become target of the bullets which will probably be aimed at
me after these modifications.
it work.
1) Socket timeout field changed from `short' to `long'. This makes longer
timeouts possible. With a 1 kHz system clock the old system allowed
timeouts only up to a little over 30 seconds! This change is a
slightly cleaned-up version of the patch proposed by Ian Lance Taylor.
2) Major changes to BOOTP/DHCP reply handling. Now supports much of
RFC2132. These changes were done at the request of, and with the
assistance of, Erik Ivanenko.
If you're making changes, you might want to change the network
supplement Essentially just do a global search and replace of BOOTP
with BOOTP/DHCP.
ports.
vector number to user ISR's and other ports could pass both the vector
number and a pointer to the ISF.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
>> >>There is a 30 day error in _TOD_Days_since_last_leap_year[2..3]
>> >Thanks.
>> >What's the condition to hit this error?
>> >Every year 4n+2 and 4n+3 ?
>> >(i.e. 1998, 1999, 2002, 2003, ...)
>> OK: 96 97 00 01 04 05 ...
>> Bad: 98 99 02 03 06 07 ...
There is also a problem in newlib 1.7.x reported at the same time:
>> I found another, that would strike only on 2/29/2000, or other leapyears.
>> Only a problem on 1 day.
>> Joel: FYI, there is a bug in Newlib localtime.c, localtime or (_tm_time).
>> Ours is modified for dst and timezones, but the bug was in original source.
>> I have not looked at the latest public source (nor do I know where to find
>> it).
This simple error resulted in the wrong FP context structure being used
for hardware contexts on the m68k. This was a difficult problem to find.
to lib/include.
in the unix port idle thread task. This should keep the entire application
from blocking when any component does a blocking application. Also added
TOD_MICROSECONDS_TO_TICKS.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
be resolved.
argument indicates whether the task is to be placed at the head or tail of
its priority fifo when it is lowering its own priority. POSIX normally
follows the RTEMS API conventions but GNAT expects that all lowering of
a task's priority by the task itself will result in being placed at the
head of the priority FIFO. Normally, this would only occur as the result
of lose of inherited priority.
need for the "sed'ing" of this file. This should be a significant win
when addressing non-unix host and non-gnu toolsets.
hardcoded 4 to be compatible with CPUs with 64-bit ints
rather than hardcoded 4 to be compatible with CPUs with 64-bit ints
of GNU C extension
the_class
switch. This was needed to support process wide signals.
can not be part of the locally blocked set since it by itself does not
indicate that the thread is blocked.
in the core to support multiple algorithms to handle cpu time budgetting
which resulted in a change to the calling sequence of _Thread_Initialize.
Makde _Context_Switch_necessary volatile.
_Thread_Ticks_remaining_in_timeslice.
by the api.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
which are tasks.
