to lib/include.
in the unix port idle thread task. This should keep the entire application
from blocking when any component does a blocking application. Also added
TOD_MICROSECONDS_TO_TICKS.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
be resolved.
argument indicates whether the task is to be placed at the head or tail of
its priority fifo when it is lowering its own priority. POSIX normally
follows the RTEMS API conventions but GNAT expects that all lowering of
a task's priority by the task itself will result in being placed at the
head of the priority FIFO. Normally, this would only occur as the result
of lose of inherited priority.
need for the "sed'ing" of this file. This should be a significant win
when addressing non-unix host and non-gnu toolsets.
hardcoded 4 to be compatible with CPUs with 64-bit ints
rather than hardcoded 4 to be compatible with CPUs with 64-bit ints
of GNU C extension
the_class
switch. This was needed to support process wide signals.
can not be part of the locally blocked set since it by itself does not
indicate that the thread is blocked.
in the core to support multiple algorithms to handle cpu time budgetting
which resulted in a change to the calling sequence of _Thread_Initialize.
Makde _Context_Switch_necessary volatile.
_Thread_Ticks_remaining_in_timeslice.
by the api.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
which are tasks.
wkspace.h: made initialization routine a regular subroutine
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
in each thread which must be set when the post switch extension is to be run.
are automatically activated upon insertion.
