path: root/c/src/exec/score/include/rtems/system.h (follow)
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-091-0/+8
| | | | for RTEMS.
* This is another pass at making sure that nothing outside the BSPJoel Sherrill1999-11-051-0/+40
| | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were defined.Joel Sherrill1997-12-061-2/+2
| | | | | This simple error resulted in the wrong FP context structure being used for hardware contexts on the m68k. This was a difficult problem to find.
* Removed definitions which are now in targopts.h. This eliminates theJoel Sherrill1997-01-291-8/+4
| | | | | need for the "sed'ing" of this file. This should be a significant win when addressing non-unix host and non-gnu toolsets.
* switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"Joel Sherrill1996-07-031-5/+3
* split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1996-05-281-8/+33
| | | | score, rtems api, or posix api related.
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-7/+8
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-9/+1
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-0/+6
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-2/+5
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Initial revisionJoel Sherrill1995-05-111-0/+132
