path: root/c/src/exec/score/include/rtems/score/threadmp.h (follow)
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+1
* Switched to events for mp receive server and eliminated the specialJoel Sherrill1995-07-311-20/+0
| | | | blocking mechanism for it.
* Initial revisionJoel Sherrill1995-05-111-0/+134
