hardcoded 4 to be compatible with CPUs with 64-bit ints
which are tasks.
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
like signal dispatching.
correct Information block.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ variable length messages
+ named devices
+ debug monitor
