path: root/c/src/exec/score/headers/mpci.h (follow)
* _MPCI_Register_packet_processor: Changed prototype of fist parameter name to ↵Mark Johannes1996-08-081-1/+1
| | | | the_class
* split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1996-05-281-5/+6
| | | | score, rtems api, or posix api related.
* Removed the internal thread objects and dispersed its contents toJoel Sherrill1996-02-211-1/+132
| | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized.
* posix support initially addedJoel Sherrill1995-09-261-7/+7
* More file movementJoel Sherrill1995-09-211-1/+2
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-22/+130
* Initial revisionJoel Sherrill1995-05-111-0/+171
