* | updated for 68302 and so gen68360 bsp would compile | Joel Sherrill | 1996-03-21 | 2 | -1/+13 |
* | Added 68360 support submitted by W. Eric Norum (eric@skatter.usask.ca). | Joel Sherrill | 1996-03-06 | 2 | -2/+12 |
| | | | | Also increased minimum stack size from 1K to 2K. | ||||
* | Dispersal of internal thread handler resulted in IDLE thread becoming | Joel Sherrill | 1996-02-21 | 11 | -52/+49 |
| | | | | | part of the Thread Handler. This required the name of the optional CPU dependent IDLE thread implementation to change. | ||||
* | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1996-02-13 | 1 | -1/+4 |
* | added clear of _ISR_Signals_to_thread_executing | Joel Sherrill | 1996-02-09 | 2 | -0/+2 |
* | increased stack size | Joel Sherrill | 1996-01-17 | 1 | -1/+1 |
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 7 | -150/+216 |
* | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 1995-12-20 | 8 | -75/+114 |
| | | | | partially recovered working tree, etc | ||||
* | Added comments for addition of is_fp flag to _CPU_Context_Initialize. | Joel Sherrill | 1995-12-05 | 1 | -0/+5 |
* | minor changes so it would compile | Joel Sherrill | 1995-12-05 | 4 | -14/+12 |
* | typos fixed | Joel Sherrill | 1995-10-31 | 8 | -8/+105 |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 18 | -840/+2100 |
* | fixed null pointer dereference | Joel Sherrill | 1995-10-06 | 1 | -2/+2 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 15 | -6/+28 |
* | SPARC merged and successfully tested w/o interrupt support | Joel Sherrill | 1995-10-06 | 8 | -1/+1866 |
* | moved to new development machine and went to gcc 2.7.0 | Joel Sherrill | 1995-10-06 | 1 | -0/+3 |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 6 | -32/+86 |
* | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1995-09-27 | 2 | -19/+339 |
| | | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | ||||
* | posix support initially added | Joel Sherrill | 1995-09-26 | 30 | -69/+69 |
* | Removed unneeded referenced to rtems/fatal.h | Joel Sherrill | 1995-09-22 | 6 | -6/+0 |
* | Removed a section of code which was "#if 0"'ed. | Joel Sherrill | 1995-09-19 | 1 | -16/+0 |
* | Incorporated the submission from John S. Gwynne | Joel Sherrill | 1995-09-19 | 6 | -70/+656 |
| | | | | | | <jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support. | ||||
* | Minor bug fixes to get all targets compilable and running. The | Joel Sherrill | 1995-09-19 | 10 | -49/+75 |
| | | | | | | single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs. | ||||
* | Initial attempt at building HP PA-RISC using Solaris hosted tools. | Joel Sherrill | 1995-09-12 | 1 | -3/+3 |
| | | | | Changed back to Newlib for Solaris UNIX simulator. | ||||
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 26 | -75/+168 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | ||||
* | Merged PowerPC port as submitted by Andy Bray of I-CUBED, Ltd | Joel Sherrill | 1995-08-22 | 9 | -0/+2803 |
| | | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language. | ||||
* | fix broken RCS Ids -- $ accidentally lost merging changes earlier | Joel Sherrill | 1995-08-22 | 6 | -6/+6 |
* | cleanup and optimization from Tony | Joel Sherrill | 1995-08-04 | 2 | -26/+20 |
* | Tony's updates | Joel Sherrill | 1995-08-04 | 1 | -4/+9 |
* | *** empty log message *** | Joel Sherrill | 1995-08-02 | 2 | -1/+13 |
* | after testing go32 and cvme961 | Joel Sherrill | 1995-07-21 | 1 | -1/+8 |
* | removed junk field in context_control | Joel Sherrill | 1995-07-20 | 1 | -1/+0 |
* | fixed for Linux | Joel Sherrill | 1995-07-18 | 1 | -0/+4 |
* | fixed for Linux | Joel Sherrill | 1995-07-18 | 1 | -13/+24 |
* | merged Linux UNIX simulator support (C) | Joel Sherrill | 1995-07-18 | 4 | -5/+53 |
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 15 | -391/+674 |
* | added David Glessner's 68302 work. | Joel Sherrill | 1995-06-14 | 1 | -5/+5 |
* | corrected pseudo-code for _ISR_Handler | Joel Sherrill | 1995-06-07 | 1 | -5/+17 |
* | incorporated mc68302 support | Joel Sherrill | 1995-06-07 | 4 | -11/+682 |
* | Added "signed" keyword to typedef of signed RTEMS types | Joel Sherrill | 1995-05-31 | 6 | -24/+24 |
* | cpu/*types.h added and successfully compiled. | Joel Sherrill | 1995-05-30 | 5 | -5/+14 |
| | | | | IDLE task priority changed from 0 to 255 during initialization. | ||||
* | Added m68ktypes.h | Joel Sherrill | 1995-05-26 | 1 | -0/+56 |
* | Created rest of CP types.h files | Joel Sherrill | 1995-05-26 | 3 | -0/+168 |
* | Added types.h file for each CPU | Joel Sherrill | 1995-05-25 | 2 | -0/+102 |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 21 | -298/+266 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 34 | -0/+9601 |
