* | Removed a section of code which was "#if 0"'ed. | Joel Sherrill | 1995-09-19 | 1 | -16/+0 |
* | Minor bug fixes to get all targets compilable and running. The | Joel Sherrill | 1995-09-19 | 1 | -29/+56 |
| | | | | | | single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs. | ||||
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 2 | -7/+28 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | ||||
* | fix broken RCS Ids -- $ accidentally lost merging changes earlier | Joel Sherrill | 1995-08-22 | 1 | -1/+1 |
* | cleanup and optimization from Tony | Joel Sherrill | 1995-08-04 | 2 | -26/+20 |
* | *** empty log message *** | Joel Sherrill | 1995-08-02 | 2 | -1/+13 |
* | removed junk field in context_control | Joel Sherrill | 1995-07-20 | 1 | -1/+0 |
* | fixed for Linux | Joel Sherrill | 1995-07-18 | 1 | -0/+4 |
* | fixed for Linux | Joel Sherrill | 1995-07-18 | 1 | -13/+24 |
* | merged Linux UNIX simulator support (C) | Joel Sherrill | 1995-07-18 | 3 | -3/+52 |
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 2 | -309/+400 |
* | Added "signed" keyword to typedef of signed RTEMS types | Joel Sherrill | 1995-05-31 | 1 | -4/+4 |
* | cpu/*types.h added and successfully compiled. | Joel Sherrill | 1995-05-30 | 1 | -1/+3 |
| | | | | IDLE task priority changed from 0 to 255 during initialization. | ||||
* | Created rest of CP types.h files | Joel Sherrill | 1995-05-26 | 1 | -0/+56 |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 3 | -38/+44 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 3 | -0/+1548 |
