vector number to user ISR's and other ports could pass both the vector
number and a pointer to the ISF.
or solaris2.
gcc-target-default.cfg
It appears that the new glibc does not clear all the bits of the signal
set with a sigprocmask.
the CPU family name constants.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
suggestion.
to lib/include.
in the unix port idle thread task. This should keep the entire application
from blocking when any component does a blocking application. Also added
TOD_MICROSECONDS_TO_TICKS.
semctl was being invoked.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
be resolved.
need for the "sed'ing" of this file. This should be a significant win
when addressing non-unix host and non-gnu toolsets.
added CPU_STRUCTURE_ALIGNMENT to default context structures
Broke the setjmp/longjmp pair in the context switch into a separate routine
so no code depended on local variables surviving the jump.
updates from Tony Bennett. Most were to insure all variables were properly
initialized and to correct the stray signal number reporting.
part of the Thread Handler. This required the name of the optional
CPU dependent IDLE thread implementation to change.
like signal dispatching.
