* cpu.c: Define fix_syscall_errno() to nothing so MP links.
* configure.ac: Fix the test to determine cpu context size.
* .cvsignore: Added stamp-h.in.
* Makefile.am: Merge in rtems/Makefile.am and
rtems/score/Makefile.am. Remove gensize. Require automake-1.5.
* rtems/Makefile.am: Removed.
* rtems/score/.cvsignore: Add unixsize.h*. Add stamp-h*.
* configure.ac: Add AM_CONFIG_HEADER(rtems/score/unixsize.h).
* rtems/score/cpu.h: Replace CPU_CONTEXT_SIZE_IN_BYTES with
SIZEOF_CPU_CONTEXT.
* Makefile.am: Add multilib support.
This was tracked as PR91.
* configure.in: Remove.
* rtems/score/cpu.h: Remove #undef __STRICT_ANSI__.
* cpu.c, rtems/score/cpu.h: Bug report from Peter Mueller
<peter.o.mueller@gmx.de> because of not correcting for the ISR
vector table now being allocated from the workspace.
* Makefile.am: Use += to set up AM_CPPFLAGS.
* rtems/score/Makefile.am: Use PROJECT_TOPdir in path to gensize.
