path: root/c/src/exec/score/cpu/sparc/cpu_asm.S (follow)
* Reworked score/cpu/sparc so it can be safely compiled multilib. AllJoel Sherrill2000-07-111-7/+0
| | | | | | routines and structures that require CPU model specific information are now in libcpu. This primarily required moving erc32 specific information from score/cpu files to libcpu/sparc and the erc32 BSP.
* Patch from Jiri Gaisler <jgais@ws.estec.esa.nl>:Joel Sherrill1999-07-091-3/+71
| | | | | | + interrupt masking correction + FPU rev.B workaround + minor erc32 related fixes
* Patch from Jiri Gaisler <jgais@ce.chalmers.se>:Joel Sherrill1999-01-191-0/+2
| | | | | | | | getting the spurious trap handling to work required a couple more fixes - I have attached a patch against rtems-4.0.0 with the necessary changes. I also added functionality so that the address of the trapped instruction is reported and in case of a data access error, the data address is also reported.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename allJoel Sherrill1998-12-141-0/+726
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake.
