* | Remove, moved to cpukit. | Ralf Corsepius | 2002-07-22 | 1 | -123/+0 |
* | Patch rtems-rc-20000801-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-08-01 | 1 | -1/+1 |
| | | | | that switches the sparc from targopts.h to cpuopts.h. | ||||
* | Reworked score/cpu/sparc so it can be safely compiled multilib. All | Joel Sherrill | 2000-07-11 | 1 | -1/+1 |
| | | | | | | routines and structures that require CPU model specific information are now in libcpu. This primarily required moving erc32 specific information from score/cpu files to libcpu/sparc and the erc32 BSP. | ||||
* | Patch from Jiri Gaisler <jgais@ws.estec.esa.nl>: | Joel Sherrill | 1999-07-09 | 1 | -0/+1 |
| | | | | | | + interrupt masking correction + FPU rev.B workaround + minor erc32 related fixes | ||||
* | Removed hack to set __USER_LABEL_PREFIX__ since late model gcc's and | Joel Sherrill | 1999-07-01 | 1 | -1/+0 |
| | | | | | egcs source tree handle this correctly. No one should be using gcc 2.7.2 anymore. | ||||
* | Moved asm.h back up in tree. | Joel Sherrill | 1999-02-19 | 1 | -0/+123 |
* | Moved to proper rtems/score | Joel Sherrill | 1999-02-19 | 1 | -123/+0 |
* | added "ifndef" to avoid redefinition warning. | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | Added include of targopts.h. | Joel Sherrill | 1997-01-29 | 1 | -1/+1 |
* | Changes to reflect new revision of erc32 per Jiri Gaisler's suggestions. | Joel Sherrill | 1996-12-02 | 1 | -0/+10 |
| | | | | This is current as of sis 2.6. | ||||
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -1/+15 |
* | SPARC merged and successfully tested w/o interrupt support | Joel Sherrill | 1995-10-06 | 1 | -0/+97 |
