> 3) rtems-rc-19990131-2.diff
> now)
> patches will apply then ;-.
To achieve this:
been removed.
cosmetic things.
ports.
old way of setting th cpu family and model string names.
Here is a pure sh-rtems bug-fix patch.
The defines to enable the network to host conversion macros in
netinet/in.h were missing in sh/cpu.h
vector number to user ISR's and other ports could pass both the vector
number and a pointer to the ISF.
