path: root/c/src/exec/score/cpu/powerpc (unfollow)
1995-09-11The word "RTEMS" almost completely removed from the core.Joel Sherrill2-12/+13
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API.
1995-08-22Merged PowerPC port as submitted by Andy Bray of I-CUBED, LtdJoel Sherrill9-0/+2803
(andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language.
