* rtems/score/cpu.h: Fix conditional to match current GCC.
* rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* rtems/Makefile.am: Removed.
* Makefile.am: Add multilib support.
This was tracked as PR91.
* configure.in: Remove.
* Shell added for or32 port based on no_cpu port with names replaced.
