path: root/c/src/exec/score/cpu/or32 (follow)
* 2001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-034-58/+9
| | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/or32types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-3/+9
* 2001-02-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-272-1/+5
| | | | * rtems/score/cpu.h: Fix conditional to match current GCC.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-053-0/+4
| | | | * rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-305-54/+35
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-192-3/+7
| | | | * Makefile.am: Add multilib support.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-282-0/+14
| | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-113-8/+16
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-273-2/+7
| | | | | * rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-053-6/+11
| | | | | * Makefile.am, rtems/score/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-032-1/+17
| | | | * rtems/score/cpu.h: Added _CPU_Initialize_vectors().
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * Makefile.am: Include compile.am.
* 2000-08-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-1117-0/+2019
* Shell added for or32 port based on no_cpu port with names replaced.
