path: root/c/src/exec/score/cpu/or32/rtems/score (follow)
* 2001-02-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-271-1/+1
| | | | * rtems/score/cpu.h: Fix conditional to match current GCC.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-051-0/+0
| | | | * rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-301-25/+0
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-281-0/+7
| | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-1/+1
| | | | | * rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-3/+3
| | | | | * Makefile.am, rtems/score/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-031-1/+13
| | | | * rtems/score/cpu.h: Added _CPU_Initialize_vectors().
* 2000-08-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-117-0/+1397
* Shell added for or32 port based on no_cpu port with names replaced.
