path: root/c/src/exec/score/cpu/mips/rtems/score/mipstypes.h (follow)
* 2001-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-141-17/+2
| | | | | | * cpu.c, rtems/score/cpu.h, rtems/score/mipstypes.h: Removed unused variable _CPU_Thread_dispatch_pointer and cleaned numerous comments.
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-181-0/+73
> 4) rtems-rc-19990202-0.diff /reorg-score-cpu.sh > > reorg-score-cpu.sh reorganizes the cpu/<cpu>/* subdirectories in a > similar manner than previous reorg scripts did. rtems-rc-19990202-0.diff > contains the diffs after reorg-score-cpu.sh has been run on a > rtems-19981215 snapshot + my patches up to rtems-rc-19990131-2.diff. > > This patch is rather nasty and may break something. However, I've tested > it for about 10 different target/bsp pairs and believe to have shaken > out most bugs. I wonder about the following .h files that were not moved: a29k/asm.h a29k/cpu_asm.h i386/asm.h i960/asm.h m68k/asm.h m68k/m68302.h m68k/m68360.h m68k/qsm.h m68k/sim.h mips64orion/asm.h mips64orion/cpu_asm.h mips64orion/mips64orion.h no_cpu/asm.h no_cpu/cpu_asm.h powerpc/asm.h powerpc/mpc860.h sh/asm.h sparc/asm.h sparc/erc32.h
