path: root/c/src/exec/score/cpu/m68k/sim.h (follow)
* 2000-10-12 John S Gwynne <jgwynne@mrcday.com>Joel Sherrill2000-10-121-5/+4
| | | | | | | | | | | | | | * sim.h: These changes enable RTEMS to automatically generate the ram_init file used by gdb with the BDM patches. The 332 has on-board chip select lines (for RAM and FLASH) that must be configured before use of these peripherals. These patches parse data from start.c where the chip select lines are configured in the runtime executable and automatically generates the gdb initialization file using the same settings. A great time saver. A similar file, ram_init_FW (flash writable), is also generated that the flash programming tool uses. * BSP/start/start.c: Must be modified to support above. * BSP/start/ram_init.ld, BSP/start/ram_init.sed: New files.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-7/+0
* Changed name of W, X, and Y macros for fields in the ClockJoel Sherrill1999-11-221-9/+9
| | | | Synthesizer Control Register to remove use of single letter names.
* Moved back up in tree.Joel Sherrill1999-02-191-0/+342
* Moved to proper rtems/scoreJoel Sherrill1999-02-191-342/+0
* changed so this file is usable from assembly files.Joel Sherrill1996-06-031-50/+64
| | | | no longer uses efi332.h
* fixed missing CVS IDsJoel Sherrill1995-10-061-0/+3
* Incorporated the submission from John S. GwynneJoel Sherrill1995-09-191-0/+325
<jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support.
