path: root/c/src/exec/score/cpu/m68k/m68360.h (follow)
* Moved back up in tree.Joel Sherrill1999-02-191-0/+889
* Moved to proper rtems/scoreJoel Sherrill1999-02-191-889/+0
* Patch from Eric Norum <eric@skatter.usask.ca> to make m68360.h usableJoel Sherrill1999-01-201-357/+366
| | | | | | | | outside RTEMS. Comment: I found a couple of places other than RTEMS where I'd like to use the declarations supplied in m68360.h. To make this easier to do, I've redone the declarations in m68360.h to use standard C types.
* Updates from Eric Norum to use the mcpu32 flags and fix comments.Joel Sherrill1996-05-011-27/+14
* added stack allocation fields to the cpu tableJoel Sherrill1996-04-221-0/+893
added CPU_M68K_EXTB_L model flag
