path: root/c/src/exec/score/cpu/m68k/asm.h (follow)
* Patch rtems-rc-20000711-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-111-1/+1
| | | | | | | | | that decouples exec/ for the sh, m68k and i960 from targopts.h. NOTE: The change to system.h is a hack to enable cpuopts.h for some targets, but keep using targopts.h for others - I know it does *not* work for sparc, mips, i386 and ppc. This will have to be addressed as work continues on multilibing.
* Moved asm.h back up in tree.Joel Sherrill1999-02-191-0/+144
* Moved to proper rtems/scoreJoel Sherrill1999-02-191-144/+0
* Merged patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to add ColdFireJoel Sherrill1998-08-011-1/+9
| | | | specific register macros and correct code in rtems.s.
* Real definition for the beginning of the data section per Eric Norum'sJoel Sherrill1998-03-241-2/+2
| | | | suggestion.
* Corrected bug per Katsutoshi Shibuya's report:Joel Sherrill1997-08-221-2/+2
| | | | | | | The definition of "BEGIN_DATA" should not be null; should be ".data". Also, the definition of "BEGIN_BSS" should be ".bss". For this error, the compiled object has codes that write on the text segment area. It is fatal when the code runs on ROM.
* Added sp, sfc, and fpcsr register defines.Joel Sherrill1997-07-091-0/+4
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-221-1/+1
* added "ifndef" to avoid redefinition warning.Joel Sherrill1997-04-071-0/+2
* Added include of targopts.h.Joel Sherrill1997-01-291-1/+2
* updated for 68302 and so gen68360 bsp would compileJoel Sherrill1996-03-211-1/+3
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+1
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-1/+1
* Initial revisionJoel Sherrill1995-05-111-0/+127
