ports.
old way of setting th cpu family and model string names.
vector number to user ISR's and other ports could pass both the vector
number and a pointer to the ISF.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
be resolved.
need for the "sed'ing" of this file. This should be a significant win
when addressing non-unix host and non-gnu toolsets.
part of the Thread Handler. This required the name of the optional
CPU dependent IDLE thread implementation to change.
like signal dispatching.
IDLE task priority changed from 0 to 255 during initialization.
