path: root/c/src/exec/score/cpu/i960/i960.h (follow)
* Removed definitions which are now in targopts.h. This eliminates theJoel Sherrill1997-01-291-22/+0
| | | | | need for the "sed'ing" of this file. This should be a significant win when addressing non-unix host and non-gnu toolsets.
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-3/+9
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-41/+33
* Initial revisionJoel Sherrill1995-05-111-0/+289
