path: root/c/src/exec/score/cpu/i960/cpu.c (unfollow)
2002-07-22Remove, moved to cpukit.Ralf Corsepius1-81/+0
2000-07-11Reworked score/cpu/i960 so it can be safely compiled multilib. AllJoel Sherrill1-108/+0
routines and structures that require CPU model specific information are now in libcpu. This required significant rework of the score/cpu header files and the creation of multiple header files and subdirectories in libcpu/i960.
2000-06-13Added crude i960ka support.Joel Sherrill1-4/+8
2000-01-14Removed warning.Joel Sherrill1-2/+2
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1999-10-27rxgen960 now compiles -- may not link.Joel Sherrill1-3/+3
1999-10-27The rxgen960 BSP and i960 RPM support was submitted by Mark BronsonJoel Sherrill1-5/+36
<mark@ramix.com> of RAMIX.
1998-02-17updated copyright to 1998Joel Sherrill1-1/+1
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill1-2/+2
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill1-5/+5
1995-09-26posix support initially addedJoel Sherrill1-1/+1
1995-09-22Removed unneeded referenced to rtems/fatal.hJoel Sherrill1-1/+0
1995-09-11The word "RTEMS" almost completely removed from the core.Joel Sherrill1-4/+15
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API.
1995-07-12Ada95, gnat, go32Joel Sherrill1-17/+38
