path: root/c/src/exec/score/cpu/i960/asm.h (follow)
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+1
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-1/+1
* Initial revisionJoel Sherrill1995-05-111-0/+107
