path: root/c/src/exec/score/cpu/i386/i386.h (follow)
* Removed definitions which are now in targopts.h. This eliminates theJoel Sherrill1997-01-291-22/+0
| | | | | need for the "sed'ing" of this file. This should be a significant win when addressing non-unix host and non-gnu toolsets.
* i386_nofp cpu model entry incorrectly had floating point enabled.Joel Sherrill1996-10-011-1/+1
* posix support initially addedJoel Sherrill1995-09-261-5/+5
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-2/+2
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-0/+12
* Ada95, gnat, go32Joel Sherrill1995-07-121-1/+1
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-28/+19
* Initial revisionJoel Sherrill1995-05-111-0/+493
