path: root/c/src/exec/score/cpu/i386/configure.ac (unfollow)
2002-07-22Remove, moved to cpukit.Ralf Corsepius1-30/+0
2002-07-052002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
2002-07-012002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-2/+0
2002-06-272002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+1
* configure.ac: Add RTEMS_PROG_CCAS
2002-06-272002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+2
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..). Add AC_PROG_RANLIB.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+2
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-01-312002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-3/+1
* rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above.
2001-10-112001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-8/+9
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
2000-07-10Patch rtems-rc-20000708-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-3/+0
that is another small step toward multilibs: Changes: * Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/ * Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme functional. Notes: * --enable-multilibs is still non-functional * This patch should not have any influence on the old building scheme (--disable-multilib should silently fall back to the old building scheme). * running ./bootstrap is required after applying the patch
2000-07-06Patch rtems-rc-20000705-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
that is a somewhat experimental, multilib-related patch: Changes: * Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in configure.ins below exec/. At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change to emphasize that these subdirectories shall not depend on RTEMS_BSP than a real behavioral change. * Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare autoheader/autoconf generated targopts.h and similiar configuration headers. * c/src/configure.in: remove exec from cfg_subdirs if multilibs are enabled (c/src is build per bsp, exec shall be build per cpu in c/ or from the toplevel in future, when multilibs are enabled.) Notes: * This patch should not have any impact on the current building scheme. * --enable-multilib still does not work. * running bootstrap from the toplevel directory is required. CVS: ---------------------------------------------------------------------- CVS: Enter Log. Lines beginning with `CVS:' are removed automatically CVS: CVS: Committing in . CVS: CVS: Modified Files: CVS: c/src/tests/libtests/termios/init.c CVS: ----------------------------------------------------------------------
2000-02-08Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-4/+1
that contains: * Removes remaining (now illegal) references to $(SRC) from a couple of Makefile.ams * Removes duplicate AC_CONFIG_SUBDIRS macro from c/configure.in * Moves ENABLE_LIBCDIR into RTEMS_PROG_C[C|XX]_FOR_TARGET (hides LIBCDIR from most configure scripts, i.e. LIBCDIR becomes less visible) * Adds RTEMS_PROG_C[C|XX]_FOR_TARGET and RTEMS_CANONICALIZE_TOOLS to libbsp/*/configure.ins (A minor bug in previous implementations, which only has an impact when switching to GNU/Cygnus canonicalization) * Cleans up several bogus comments. * Removes MKLIB * Switches the version number to 4.5.0 (for testing version number handling)
2000-01-31Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-3/+0
that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
1999-12-01 Patch rtems-rc-19991123-rc-2.diff from Ralf CorsepiusJoel Sherrill1-1/+1
<corsepiu@faw.uni-ulm.de> which implements automake support for some score/cpu/<RTEMS_CPU> subdirectories and fixes a few minor configuration bugs. To apply: rm -rf c/src/exec/score/cpu/a29k/wrap rm -rf c/src/exec/score/cpu/hppa1.1/wrap rm -rf c/src/exec/score/cpu/i386/wrap rm -rf c/src/exec/score/cpu/mips64orion/wrap rm -rf c/src/exec/score/cpu/no_cpu/wrap patch -p1 < rtems-rc-19991123-rc-2.diff.gz Notes: * I don't see a possiblity to convert the powerpc subdirectory in its current layout to automake the time being. * Besides the fact that this subdirectory is not in single-tree building layout, the actual showstopper is the ifeq $(RTEMS_CPU_MODEL),mpc750) gmake-conditional in powerpc/Makefile.in, which automake (correctly) refuses to handle. * The problem is *not* specific to the powerpc. Other CPUs basically have similar problems (SH:sh7032 vs sh7045, SPARC: erc32.h in score/cpu/sparc), but have been lucky to get around real issues (cf. configuration files below score/cpu/sh/). * From a configuration focused POV this problem boils down to a file/subdirectory selection problem: ppc: 1 or others sh: 1 out of 2 sparc: 1 out of 1 Automake's means to implement such behavior is using conditionals to be evaluated at configuration-time. The old configuration scheme however used make-time conditionals. The SH port was lucky to get around this issue because it applies a selection from a limited set of possible selections, the powerpc however applies a selection from an unlimited set, based on data not being available at configuration time. * Currently I only see two general solutions: 1) make RTEMS_CPU_MODEL available at configuration time, ie. replace make-time configuration by configuration-time configuration 2) Perform the selection at build-time, i.e. always install all files, but use #ifdef #else #endif in source files. This is what the m68k has exploited at other locations inside of the source-tree. => This directory is the last one remaining not using automake below the whole exec/ hierarchy.
1999-12-01Patch rtems-rc-19991123-rc-1.diff from Ralf CorsepiusJoel Sherrill1-17/+14
<corsepiu@faw.uni-ulm.de> which implements automake support for some score/cpu/<RTEMS_CPU> subdirectories and fixes a few minor configuration bugs. To apply: rm -rf c/src/exec/score/cpu/i960/wrap rm -rf c/src/exec/score/cpu/m68k/wrap rm -rf c/src/exec/score/cpu/sh/wrap rm -rf c/src/exec/score/cpu/sparc/wrap rm -rf c/src/exec/score/cpu/unix/wrap patch -p1 < rtems-rc-19991123-rc-1.diff ./bootstrap Known bugs: * "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does not handle recursion to subdirectories correctly (recurses too often). However, this issue is hardly visible and should be tolerable for the moment.
1999-10-04Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-18/+15
The patch below actuallly consists of two patches: 1) moving librpc to c/src/librpc similar to what has been done to librtems++ 2) reworked configure scripts, many safety and dependency checks added to aclocal/*.m4 macros + configuration fixes. To apply: mkdir c/src/librpc mkdir c/src/librpc/src cp c/src/lib/librpc/*.c c/src/librpc/src cp c/src/lib/librpc/Makefile.in c/src/librpc/src mkdir c/src/librpc/include mkdir c/src/librpc/include/rpc cp c/src/lib/include/rpc/* c/src/librpc/include/rpc patch -p1 < ../rtems-rc-19990820-7.diff rm -rf c/src/lib/librpc rm -rf c/src/lib/include/rpc ./autogen The additional checks in aclocal/*m4 macros add rather restrictive, sometimes unnecessarily restrictive constraints on the sequence of how macros can be used in a configure.in script. Adding them has let my problems with some more complicated configuration options vanish. Apparently some macros had not been in the required order . ---- Now I still get some linking errors for some cpus and bsps, esp when linking cdtest, but also at other locations: e.g. this happens for mips64orion/p4600: # make[5]: Entering directory `/lfs/poseidon/users/rtems/src/multi/build/mips64orion-rtems/c/p4600/tests/samples/hello' /opt/rtems/bin/mips64orion-rtems-gcc --pipe -B../../../../../../p4600/lib/ -specs bsp_specs -qrtems -DP4000 -DCPU_R4000 -DP3_DIAG -D_R4000 -D__mips=3 -mcpu=4600 -G0 -I../../../../../../p4600/lib/include/networking -g -Wall -ansi -fasm -O4 -fomit-frame-pointer -o o-p4600/hello.exe o-p4600/init.o ../../../../../../p4600/lib/no-dpmem.rel ../../../../../../p4600/lib/no-event.rel ../../../../../../p4600/lib/no-msg.rel ../../../../../../p4600/lib/no-mp.rel ../../../../../../p4600/lib/no-part.rel ../../../../../../p4600/lib/no-signal.rel ../../../../../../p4600/lib/no-timer.rel ../../../../../../p4600/lib/no-rtmon.rel /opt/rtems/mips64orion-rtems/lib/libc.a(dtoa.o): In function `_dtoa_r': /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol collect2: ld returned 1 exit status # mips64orion-rtems-gcc -v Reading specs from /opt/rtems/lib/gcc-lib/mips64orion-rtems/2.95.1/specs gcc version 2.95.1 19990816 (release) # mips64orion-rtems-ld -v GNU ld version 2.9.5 (with BFD 2.9.5)
1999-10-04Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-2/+0
1999-09-07Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1-10/+19
Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files.
1999-08-10New configuration files added by patch fromJoel Sherrill1-0/+39
