old way of setting th cpu family and model string names.
Now that Joel told me how to compile outside the tree,
I have found a few more bugs. Here is a small patch
to fix them.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
