* rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* rtems/Makefile.am: Removed.
* Makefile.am: Corrected so .h files from rtems/score/ are installed.
* cpu.c: Include rtems/bspIo.h instead of bspIo.h.
* Makefile.am: Add multilib support.
This was tracked as PR91.
* configure.in: Remove.
* ChangeLog: Removed duplicate entry.
* rtems/score/i386.h: Corrected "#elsif" to be "#elif".
* rtems/score/i386.h: cpu-variant define handling
Rewrite due to introduction of multilib defines.
* asm.h: include cpuopts.h instead of targopts.h
