* configure.ac: Add RTEMS_PROG_CCAS
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..).
Add AC_PROG_RANLIB.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
* rtems/score/idtr.h: New file, extracted from libcpu/cpu.h.
* rtems/score/interrupts.h: New file, extracted from libcpu/cpu.h.
* rtems/score/registers.h: New file, moved from libcpu.
* cpu.c: Don't include cpuModel.h,
#include <rtems.h>,
#include <rtems/score/i386types.h>,
#include <rtems/score/idtr.h>.
* rtems/score/cpu.h: Don't include libcpu/cpu.h.
#include <rtems/score/interrupts.h>,
#include <rtems/score/registers.h>.
* rtems/score/i386types.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* rtems/Makefile.am: Removed.
* Makefile.am: Corrected so .h files from rtems/score/ are installed.
* cpu.c: Include rtems/bspIo.h instead of bspIo.h.
* Makefile.am: Add multilib support.
This was tracked as PR91.
* configure.in: Remove.
* ChangeLog: Removed duplicate entry.
* rtems/score/i386.h: Corrected "#elsif" to be "#elif".
* rtems/score/i386.h: cpu-variant define handling
Rewrite due to introduction of multilib defines.
* asm.h: include cpuopts.h instead of targopts.h
