* Makefile.am, cpu.c, cpu_asm.S, rtems.S: Modified to make
this all compile again. It has been a while since we have
had a semi-working hppa1.1-rtems cross compiler. :)
Changed back to Newlib for Solaris UNIX simulator.
like signal dispatching.
