path: root/c/src/exec/score/cpu/h8300 (follow)
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-305-57/+37
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above.
* 2002-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-082-0/+6
| | | | * rtems/score/cpu.h: #include <rtems/bspIo.h>.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-192-3/+7
| | | | * Makefile.am: Add multilib support.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-282-0/+14
| | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-113-8/+16
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-273-2/+7
| | | | | * rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-053-6/+11
| | | | | * Makefile.am, rtems/score/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-033-2/+16
| | | | | | * rtems/score/cpu.h: Added _CPU_Initialize_vectors(). * cpu_asm.S: Modify to properly dereference _ISR_Vector_table now that it is dynamically allocated.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-183-17/+29
| | | | | | | * cpu_asm.S, rtems/score/cpu.h: Modified to better support multilibing. These changes result in the code being able to compile with the default gcc settings. It is not functional in this configuration but does compile.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * Makefile.am: Include compile.am.
* Update from Philip Quaife <rtemsdev@qs.co.nz> that was hand-merged.Joel Sherrill2000-07-172-34/+75
| | | | | | | | | | This update addresses the following: + the ISR enable/disable/flash macros now work with old gcc versions. + the UI CCR bits are now masked since other example code did so + _ISR_Dispatch disables interrupts during call setup Together these removed the instabilities he was seeing.
* Patch rtems-rc-20000708-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-101-3/+0
| | | | | | | | | | | | | | | | | that is another small step toward multilibs: Changes: * Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/ * Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme functional. Notes: * --enable-multilibs is still non-functional * This patch should not have any influence on the old building scheme (--disable-multilib should silently fall back to the old building scheme). * running ./bootstrap is required after applying the patch
* Patch rtems-rc-20000705-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-061-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is a somewhat experimental, multilib-related patch: Changes: * Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in configure.ins below exec/. At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change to emphasize that these subdirectories shall not depend on RTEMS_BSP than a real behavioral change. * Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare autoheader/autoconf generated targopts.h and similiar configuration headers. * c/src/configure.in: remove exec from cfg_subdirs if multilibs are enabled (c/src is build per bsp, exec shall be build per cpu in c/ or from the toplevel in future, when multilibs are enabled.) Notes: * This patch should not have any impact on the current building scheme. * --enable-multilib still does not work. * running bootstrap from the toplevel directory is required. CVS: ---------------------------------------------------------------------- CVS: Enter Log. Lines beginning with `CVS:' are removed automatically CVS: CVS: Committing in . CVS: CVS: Modified Files: CVS: c/src/tests/libtests/termios/init.c CVS: ----------------------------------------------------------------------
* Interrupt stack is allocated in _ISR_Handler_initialization notJoel Sherrill2000-07-031-1/+1
| | | | _Interrupt_Manager_initialization.
* Changed extra_system_initialization_stack to extra_mpci_receive_server_stackJoel Sherrill2000-07-031-1/+1
| | | | to be consistent with other ports.
* This is the initial addition of the port of RTEMS to theJoel Sherrill2000-06-2916-0/+2025
Hitachi H8 family. This port was done by Philip Quaife <philip@qs.co.nz> of Q Solutions and sponsored by Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1 to a Hitach H8300H. The port was updated to RTEMS 4.5 style Makefiles/configure by Joel Sherrill <joel@OARcorp.com>. While doing this Joel added support for the h8300-rtems to binutils, gcc, newlib, and gdb. NOTE: Philip submitted a BSP for a Hitachi evaluation board which is being merged as a separate entity.
