* rtems/Makefile.am: Removed.
This was tracked as PR91.
* rtems/score/c4x.h: Modified to properly multilib. This required
using only macros predefined by gcc.
* Makefile.am: Include compile.am, formatting.
* rtems/Makefile.am: formatting.
* rtems/score/Makefile.am: formatting.
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
