* | Remove, moved to cpukit. | Ralf Corsepius | 2002-07-22 | 1 | -30/+0 |
* | 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-05 | 1 | -1/+1 |
| | | | | * configure.ac: RTEMS_TOP(../../../..). | ||||
* | 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-01 | 1 | -2/+0 |
| | | | | * configure.ac: Remove RTEMS_PROJECT_ROOT. | ||||
* | 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-27 | 1 | -0/+1 |
| | | | | * configure.ac: Add RTEMS_PROG_CCAS | ||||
* | 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-27 | 1 | -1/+2 |
| | | | | | * configure.ac: Use AC_CONFIG_AUX_DIR(../../../..). Add AC_PROG_RANLIB. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -2/+2 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-30 | 1 | -3/+1 |
| | | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above. | ||||
* | 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-06 | 1 | -3/+0 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | ||||
* | 2001-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-12-20 | 1 | -1/+1 |
| | | | | * configure.ac: Use RTEMS_ENV_RTEMSCPU. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 1 | -0/+35 |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. |
