* configure.ac: Add RTEMS_PROG_CCAS
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..).
Add AC_PROG_RANLIB.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
* rtems/score/c4xtypes.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/Makefile.am: Removed.
* asm.h: Remove #include <rtems/score/targopts.h>.
Add #include <rtems/score/cpuopts.h>.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* configure.ac: Use RTEMS_ENV_RTEMSCPU.
* Makefile.am: Add multilib support.
This was tracked as PR91.
* configure.in: Remove.
* rtems/score/c4x.h: Modified to properly multilib. This required
using only macros predefined by gcc.
* Makefile.am: Include compile.am, formatting.
* rtems/Makefile.am: formatting.
* rtems/score/Makefile.am: formatting.
