* configure.ac: Removed references to rtems/Makefile and
rtems/score/Makefile.
* rtems/Makefile.am: Removed.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* cpu.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Use RTEMS_ENV_RTEMSCPU.
* Makefile.am: Add multilib support.
* asm.h: include cpuopts.h instead of targopts.h
* rtems/score/arm.h: Use __arm__.
This was tracked as PR91.
* configure.in: Remove.
* Makefile.am: Include compile.am, formatting.
* rtems/Makefile.am: Formatting.
* rtems/score/Makefile.am: Formatting.
* cpu.c: Spacing issues.
* rtems/score/cpu.h: Removed warning by setting _level.
2000-08-29 Joel Sherrill <joel.sherrill@OARcorp.com>
* Makefile.am: Added S_O_FILES to list of objects.
