path: root/c/src/exec/score/cpu/arm/rtems/score (follow)
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-301-25/+0
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above.
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-181-1/+1
| | | | | * asm.h: include cpuopts.h instead of targopts.h * rtems/score/arm.h: Use __arm__.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-281-0/+7
| | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-1/+1
| | | | | * rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-3/+3
| | | | | * Makefile.am, rtems/score/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-031-0/+7
| | | | * rtems/score/cpu.h: Added _CPU_Initialize_vectors().
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-5/+4
| | | | | | * Makefile.am: Include compile.am, formatting. * rtems/Makefile.am: Formatting. * rtems/score/Makefile.am: Formatting.
* 2000-08-28 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-291-0/+1
| | | | | * cpu.c: Spacing issues. * rtems/score/cpu.h: Removed warning by setting _level.
* Port of RTEMS to the ARM processor family by Eric ValetteJoel Sherrill2000-07-277-0/+1177
<valette@crf.canon.fr> and Emmanuel Raguet <raguet@crf.canon.fr> of Canon CRF - Communication Dept. This port includes a basic BSP that is sufficient to link hello world.
