* Makefile.am: Add multilib support.
This was tracked as PR91.
* configure.in: Remove.
* rtems/score/a29k.h, rtems/score/cpu.h: Switched to using
cpuopts.h not targopts.h to reduce dependency on BSP.
* amd.ah, cpu.c, cpu_asm.S, register.ah, sig.S, rtems/score/cpu.h:
Updated and fixed minor things. Commented out offensive assembly
and made applications link.
* Makefile.am, cpu_asm.S, psmacro.ah, rtems/score/cpu.h:
First attempt to compile with GNU tools. Minor modifications
to compile enough to get to assembler errors.
* Makefile.am: Include compile.am, remove duplicate includes.
that is another small step toward multilibs:
* Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/
* Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in
RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme
functional.
* --enable-multilibs is still non-functional
* This patch should not have any influence on the old building
scheme (--disable-multilib should silently fall back to the old
building scheme).
* running ./bootstrap is required after applying the patch
that is a somewhat experimental, multilib-related patch:
* Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in
configure.ins below exec/.
At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change
to emphasize that these subdirectories shall not depend on RTEMS_BSP
than a real behavioral change.
* Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare
autoheader/autoconf generated targopts.h and similiar configuration
headers.
* c/src/configure.in: remove exec from cfg_subdirs if multilibs are
enabled (c/src is build per bsp, exec shall be build per cpu in c/
or from the toplevel in future, when multilibs are enabled.)
* This patch should not have any impact on the current building scheme.
* --enable-multilib still does not work.
* running bootstrap from the toplevel directory is required.
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
_Interrupt_Manager_initialization.
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
bugs.
rm -rf c/src/exec/score/cpu/a29k/wrap
rm -rf c/src/exec/score/cpu/hppa1.1/wrap
rm -rf c/src/exec/score/cpu/i386/wrap
rm -rf c/src/exec/score/cpu/mips64orion/wrap
rm -rf c/src/exec/score/cpu/no_cpu/wrap
patch -p1 < rtems-rc-19991123-rc-2.diff.gz
* I don't see a possiblity to convert the powerpc subdirectory in its
current layout to automake the time being.
* Besides the fact that this subdirectory is not in single-tree building
layout, the actual showstopper is the ifeq $(RTEMS_CPU_MODEL),mpc750)
gmake-conditional in powerpc/Makefile.in, which automake (correctly)
refuses to handle.
* The problem is *not* specific to the powerpc. Other CPUs basically
have similar problems (SH:sh7032 vs sh7045, SPARC: erc32.h in
score/cpu/sparc), but have been lucky to get around real issues (cf.
configuration files below score/cpu/sh/).
* From a configuration focused POV this problem boils down to a
file/subdirectory selection problem:
ppc: 1 or others
sh: 1 out of 2
sparc: 1 out of 1
Automake's means to implement such behavior is using conditionals to be
evaluated at configuration-time. The old configuration scheme however
used make-time conditionals. The SH port was lucky to get around this
issue because it applies a selection from a limited set of possible
selections, the powerpc however applies a selection from an unlimited
set, based on data not being available at configuration time.
* Currently I only see two general solutions:
1) make RTEMS_CPU_MODEL available at configuration time, ie. replace
make-time configuration by configuration-time configuration
2) Perform the selection at build-time, i.e. always install all files,
but use #ifdef #else #endif in source files. This is what the m68k has
exploited at other locations inside of the source-tree.
=> This directory is the last one remaining not using automake below the
whole exec/ hierarchy.
bugs.
refuses to handle.
ppc: 1 or others
sh: 1 out of 2
sparc: 1 out of 1
bugs.
refuses to handle.
ppc: 1 or others
sh: 1 out of 2
sparc: 1 out of 1
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
dependencies of "Makefile".
--enable-maintainer-mode.
directories.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
> 3) rtems-rc-19990131-2.diff
> now)
> patches will apply then ;-.
To achieve this:
been removed.
ports.
