* cpu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rtems/score/watchdog.h: Added WATCHDOG_MAXIMUM_INTERVAL.
* include/rtems/system.h: Fix typo in yesterday's change:
RTEMS_MULTILIBS.
* include/rtems/system.h: Only include cpuopts.h when building a
multilib configuration. Some ports still need targopts.h but this
small modification lets those ports work non-multilib while
fixing being fixed for multilib.
* include/rtems/seterr.h: Add do {..} while (0) in defines.
Rename set_errno_and_return_minus_one into
rtems_set_errno_and_return_minus_one.
* inline/rtems/score/object.inl, macros/rtems/score/object.inl: Add
add casts to Objects_Id in _Objects_Build_ids to avoid implicit
typecasts from enum to int16 on bit16 targets (here: h8300).
* src/Makefile.am: Add multilib support.
This was tracked as PR91.
* include/rtems/score/isr.h, inline/rtems/score/isr.inl,
macros/rtems/score/isr.inl: Modified to allow any port to provide
its own implementation of the macro _ISR_Is_in_progress. If the
port overrides this macro, it must provide a non-inlined function
implementation.
* src/threadhandler.c: When __USE__MAIN__ is defined by the toolset,
invoke the global constructors via __main. Reported as tested by
Alexandra Kossovsky <sasha@oktet.ru> and Victor V. Vengerov
<vvv@oktet.ru> in conjunction with a new set of tool RPMs
(gcc2.95.3newlib1.9.0-3). This was tracked as GNATS PR tools/84.
Reported by Todor.Todorov@barco.com and tracked as PR36.
* include/rtems/score/object.h: Added prototype for
_Objects_Get_by_index().
* src/objectget.c, src/objectgetisr.c: Corrected procedure for
getting index from Id so it is correct and optimal for both single
and multiprocessor configurations.
* src/threadhandler.c: Use __USE_INIT_FINI__ since USE_INIT_FINI
pollutes the application namespace.
* .cvsignore: Add stamp-h.in.
* include/Makefile.am: Fixed path to cpuopts-tmp.h.
* macros/rtems/score/Makefile.am: Remove.
* macros/Makefile.am: Handle subdirs, require automake-1.5.
* inline/rtems/score/Makefile.am: Remove.
* Makefile.am: require automake-1.5
* include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/threadhandler.c: Now process C++ global constructors
(_init) as part of the first task execution not in BSP space.
This depends on the toolset defining USE_INIT_FINI so you
have to have the right toolset version.
* src/coremutex.c, src/coremutexseize.c, src/coremutexsurrender.c,
inline/rtems/score/coremutex.inl: The per thread field resource_count
should only be manipulated when a mutex is priority ceiling or
priority inherit. This was reported by Chris Johns <ccj@acm.org>
who also noticed that the use of switches for all disciplines
generated less efficient code than using explicit tests for the one
or two cases we were really interested in. Further review of his
modifications made it apparent that the "isa" methods to test mutex
discipline were not being used so this modification was swept into
the code as well.
* src/coremutexseize.c: Add missing code for proper handling
of nesting acquisitions. This only impacts building with
inlines disabled on the source with the "fast mutex" optimizations.
This was post the 4.5 branch and did not impact released versions.
* src/coremutexsurrender.c: Use holder thread not executing
thread because even though they may and often are the same
it is not guaranteed unless the proper attribute is set.
* include/rtems/score/coremsg.h, src/coremsgsubmit.c: Add a new
return status to account for blocking sends. Otherwise, the
caller will think that the returned message status will have
the ultimate results of the operation. If the send times out,
the final status will be in the return_code of the thread.
* include/rtems/score/coremsg.h, inline/rtems/score/coremsg.inl,
src/coremsgsubmit.c: Unblocking message queue operations should
by Suvrat Gupta <suvrat@utstar.com>.
* macros/rtems/score/coresem.inl, inline/rtems/score/coresem.inl:
Cut and paste problem incorrectly enabled interrupts twice with
the first time being too early.
* include/rtems/score/.cvsignore: Add stamp-h, cpuopts.h,
cpuopts.h.in, cpuopts-tmp.h.
* include/rtems/Makefile.am, include/rtems/score/Makefile.am,
inline/rtems/score/Makefile.am, macros/rtems/score/Makefile.am
* src/objectextendinformation.c: Added include of string.h to
eliminate warning.
* src/threadinitialize.c: Fix my bad hack of Ralf's fp_area
warning removal patch. :(
* src/threadinitialize.c: Removed warning.
* src/isr.c: Allocate the _ISR_Vector_table all the time not just when
we are allocating an interrupt stack.
* include/rtems/score/isr.h, src/isr.c: Allocate it from the
workspace rather than explicitly declaring it. This allows
the size to be a non-constant from the perspective of score/cpu.
* macros/rtems/score/coresem.inl: Removed comments since convention
calls for comments to be in inline versin.
* macros/rtems/score/object.inl (Objects_Get_local_object): Fixed
style to use _ prefix on variable names and use parentheses.
* macros/rtems/score/object.inl (_Objects_Namespace_remove): Added.
* General effort to make things compile with macros not inlines
* inline/rtems/score/coremutex.inl: Added comment indicating
for macros there is another copy of
_CORE_mutex_Seize_interrupt_trylock() in src/coremutexseize.c.
* src/coremutexseize.c: Added body of
_CORE_mutex_Seize_interrupt_trylock() for macro case.
* macros/rtems/score/coremutex.inl: Added prototype for
_CORE_mutex_Seize_interrupt_trylock() since there is a real
body when macros are enabled.
* macros/rtems/score/coresem.inl: Added macro implementation of
_CORE_semaphore_Seize_isr_disable.
* macros/score/Makefile.am: Fixed typos.
* rtems/score/address.inl: Correct macro implementation of
_Addresses_Is_aligned() so it would compile.
* macros/rtems/score/coremsg.inl: Added closing parentheses.
* src/heapallocate.c: Do not allow the size to overflow when
adjusting it. A test allocated a stack of -1 (~0). This
actually resulted in a stack being allocated but with a
size of 0xb. The allocator did not test the size to see if
it rolled through 0 and so allowed the allocation to happen, the
thread to get created. The task crashed as you would expect.
* include/rtems/system.h: Use proper conditional (RTEMS_POSIX_API)
so prototypes for POSIX_MP_NOT_IMPLEMENTED(), POSIX_NOT_IMPLEMENTED(),
POSIX_BOTTOM_REACHED() are actually included.
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL
with an RTEMS specific but more restrictive autoconf macro.
* src/heapgetinfo.c, include/rtems/score/heap.h, src/Makefile.am:
Added _Heap_Get_information() and information control block.
* src/heapgetinfo.c: New file.
* rtems/system.h: Switched a29k and hppa1.1 to using cpuopts.h not
targopts.h to reduce dependency on BSP.
* src/objectgetbyindex.c: Do not enable dispatching on an
error path it was not disabled on.
* src/Makefile.am: Include compile.am.
all APIs.
* include/rtems/system.h: Include cpuopts.h for __i386__.
