* | changed version to 980819 | Joel Sherrill | 1998-08-19 | 2 | -2/+2 | |
* | changed version to 980808 | Joel Sherrill | 1998-08-08 | 2 | -2/+2 | |
* | changed version to 9800808 | Joel Sherrill | 1998-08-08 | 2 | -2/+2 | |
* | changed version to 980724 | Joel Sherrill | 1998-07-24 | 2 | -2/+2 | |
* | changed version to 980723 | Joel Sherrill | 1998-07-23 | 2 | -2/+2 | |
* | changed version to 980710 | Joel Sherrill | 1998-07-10 | 2 | -2/+2 | |
* | changed version to 980707 | Joel Sherrill | 1998-07-07 | 2 | -2/+2 | |
* | changed version to 9800707 | Joel Sherrill | 1998-07-07 | 2 | -2/+2 | |
* | changed version to 980618 | Joel Sherrill | 1998-06-18 | 2 | -2/+2 | |
* | changed version to 980604 | Joel Sherrill | 1998-06-04 | 2 | -2/+2 | |
* | changed version to 980527 | Joel Sherrill | 1998-05-27 | 2 | -2/+2 | |
* | Corrected interrupt stack allocation. | Joel Sherrill | 1998-05-27 | 2 | -6/+14 | |
* | changed version to 980521 | Joel Sherrill | 1998-05-21 | 2 | -2/+2 | |
* | changed version to 980518 | Joel Sherrill | 1998-05-18 | 2 | -2/+2 | |
* | Include memory for Ada task stacks. | Joel Sherrill | 1998-05-18 | 2 | -4/+4 | |
* | Added default value for CONFIGURE_MAXIMUM_POSIX_THREADS since it is | Joel Sherrill | 1998-05-04 | 2 | -0/+2 | |
| | | | | | used to calculate the amount of memory used by tasks whether the POSIX API is enabled or disabled. | |||||
* | Removed redundant "* 1024" which exploded the size of the workspace. | Joel Sherrill | 1998-04-30 | 2 | -4/+4 | |
* | Added numerous entries to make the memory calculation more accurate: | Joel Sherrill | 1998-04-27 | 2 | -2/+134 | |
| | | | | | | | | | | | | | + POSIX threads + Ada tasks + POSIX threads API support + POSIX condition variables + POSIX keys (still do not account for data fields) + POSIX mutexes + POSIX queued signals + added macro for extra memory for task stacks + default value for CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + extra memory for Ada task stacks | |||||
* | Changed to account for libio's maximum_semaphores as well as its | Joel Sherrill | 1998-04-18 | 2 | -2/+10 | |
| | | | | | | memory requirements. Also added variable to tell libio how many file descriptors to allocate. | |||||
* | Changed version number so script will work. | Joel Sherrill | 1998-04-18 | 2 | -2/+2 | |
* | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 1998-04-15 | 2 | -2/+18 | |
| | | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | |||||
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 5 | -10/+57 | |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | |||||
* | changed version to ralf-980414 | Joel Sherrill | 1998-04-14 | 2 | -2/+2 | |
* | Account for interrupt stack space | Joel Sherrill | 1998-04-14 | 2 | -2/+24 | |
* | Added stack checker extension | Joel Sherrill | 1998-04-14 | 2 | -4/+28 | |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 2 | -8/+32 | |
| | | | | by newlib. | |||||
* | changed version to 4.0.0-beta2 | Joel Sherrill | 1998-03-31 | 2 | -2/+2 | |
* | changed version to 4.0.0-beta1 | Joel Sherrill | 1998-03-24 | 2 | -2/+2 | |
* | Added misisng line continuation. | Joel Sherrill | 1998-02-20 | 2 | -2/+2 | |
* | changed version to 980219 | Joel Sherrill | 1998-02-19 | 2 | -2/+2 | |
* | Accounted for fixed system overhead. | Joel Sherrill | 1998-02-19 | 2 | -4/+20 | |
* | changed version to 980218 | Joel Sherrill | 1998-02-18 | 2 | -2/+2 | |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 29 | -29/+29 | |
* | Installing sptables with version information. | Joel Sherrill | 1998-02-17 | 2 | -6/+6 | |
* | renamed init.c exinit.c | Joel Sherrill | 1998-02-17 | 1 | -1/+1 | |
* | First cut at automatic insertion of version information. | Joel Sherrill | 1998-02-17 | 4 | -6/+28 | |
* | Patch from Ralf Corsepius to reduce the amount of memory consumed by | Joel Sherrill | 1998-02-04 | 2 | -4/+12 | |
| | | | | the workspace by default. | |||||
* | Big patch form Ralf Corsepius described in this email: | Joel Sherrill | 1998-01-30 | 9 | -36/+18 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Here is the result of my nightly work to get RTEMS_ROOT=$srcdir working with different shells and relative/absolute paths. What I did is relatively simple in principle: Instead of setting RTEMS_ROOT in configure.in and then let configure substitute @RTEMS_ROOT@ inside the Makefiles, I now let each Makefile set RTEMS_ROOT from each Makefile's @top_srcdir@ value. The difference is subtile, but with enormous side effects: - If RTEMS_ROOT is set in configure, then the same single value will be propagated to all Makefiles. This breaks using relative paths, as the relative path to the root of the source tree is used inside of all subdirectory Makefiles. - Now each Makefile.in sets RTEMS_ROOT = @top_srcdir@. top_srcdir is computed individually by configure for each single Makefile.in, hereby receiving the correct value, no matter if relative or absolute paths are used. To get this working, I needed to remove setting RTEMS_ROOT from target.cfg.in, because this overrides the value of RTEMS_ROOT from each individual Makefile. Furthermore, I removed RTEMS_CUSTOM from the Makefiles and replaced all "include $(RTEMS_CUSTOM)" directives with"include $(RTEMS_ROOT)/make/custom/$(RTEMS_BSP)". Perhaps you don't like this, but I think, to have one variable less is clearer and easier to understand than having several variables refering to the next one. I enclose a small patch to this mail, which - fixes the config.h problem (to finally clearify misunderstands) - removes assignment/subsitution of RTEMS_ROOT from configure.in - contains a workaround for the application Makefile's RTEMS_ROOT problem (reported by Eric) - removes some unused lines from the toplevel Makefile.in - removes assignment of RTEMS_ROOT from make/target.cfg.in | |||||
* | Removed CONFIG_DIR and PROJECT_HOME directories. | Joel Sherrill | 1998-01-20 | 9 | -9/+9 | |
* | Added CONFIGURE_GNAT_KEYS to correct the number of keys configured | Joel Sherrill | 1997-12-23 | 2 | -24/+22 | |
| | | | | | | | | | for GNAT. It was the number of Ada tasks when in fact the run-time only required a single key. Also added the CONFIGURE_MAXIMUM_FAKE_ADA_TASKS constant to account for resources allocated for each non-Ada task/thread which invokes the Ada run-time implicitly through an Ada call. | |||||
* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 9 | -9/+36 | |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | |||||
* | Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request. | Joel Sherrill | 1997-11-18 | 2 | -2/+12 | |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 31 | -62/+62 | |
* | Removed include directory at "build" point and the link of this directory | Joel Sherrill | 1997-10-08 | 7 | -9/+9 | |
| | | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable. | |||||
* | Added GNAT configuration parameters. | Joel Sherrill | 1997-08-04 | 2 | -8/+38 | |
* | Added postswitch extension. | Joel Sherrill | 1997-07-09 | 2 | -0/+4 | |
* | changed version number to 4.1.0. | Joel Sherrill | 1997-05-27 | 2 | -2/+2 | |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 31 | -155/+155 | |
| | | | | of switching to the modified GNU GPL. | |||||
* | enhanced rtems_shutdown_executive to insure that no attempt will | Joel Sherrill | 1997-04-09 | 1 | -1/+4 | |
| | | | | be made to shut the system down when it is down. | |||||
* | was checking for null cpu_table -- short have been checking configuration | Joel Sherrill | 1997-04-02 | 1 | -1/+1 | |
| | | | | table. |
