* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 2 | -8/+8 |
* | changed version | Joel Sherrill | 1996-07-03 | 2 | -2/+2 |
* | fields for init threads stuff said tasks. | Joel Sherrill | 1996-06-14 | 1 | -4/+4 |
* | added maximum_queued_signals to _POSIX_Default_configuration | Mark Johannes | 1996-06-13 | 1 | -0/+1 |
* | added posix configuration parameter maximum_queued_signals. | Joel Sherrill | 1996-06-13 | 2 | -0/+10 |
* | now passing maximum_queued_signals to posix signals manager initialization | Joel Sherrill | 1996-06-13 | 1 | -1/+3 |
* | Added include so _POSIX_signals_Manager_initialization is prototyped. | Joel Sherrill | 1996-06-13 | 1 | -0/+1 |
* | added initialization of posix signal manager. | Joel Sherrill | 1996-06-12 | 1 | -0/+2 |
* | added an assert if a pthread_t is not the same size as an Objects_Id | Joel Sherrill | 1996-06-03 | 1 | -2/+5 |
* | tests now specify whether using posix initialization threads table | Joel Sherrill | 1996-05-29 | 2 | -26/+90 |
| | | | | or rtems initialization table in configuration table | ||||
* | fixed support for posix initialization threads table | Joel Sherrill | 1996-05-29 | 2 | -4/+44 |
* | Addressed RTEMS API initialization tasks table in a system without | Joel Sherrill | 1996-05-29 | 2 | -6/+14 |
| | | | | RTEMS initialization tasks. | ||||
* | Added default POSIX API configuration table. | Joel Sherrill | 1996-05-29 | 1 | -1/+13 |
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 9 | -32/+46 |
| | | | | score, rtems api, or posix api related. | ||||
* | added maximum keys | Joel Sherrill | 1996-05-28 | 2 | -2/+2 |
* | new file | Joel Sherrill | 1996-05-28 | 1 | -0/+72 |
* | added ifndef's for the POSIX maximum field in the POSIX api configuration table | Joel Sherrill | 1996-05-28 | 2 | -2/+12 |
* | added posix api initialization call to init.c | Joel Sherrill | 1996-05-28 | 2 | -1/+5 |
| | | | | deleted a blank line in rtemsapi.c | ||||
* | made posix configuration information conditional so configurations wanting | Joel Sherrill | 1996-05-28 | 4 | -2/+98 |
| | | | | only the rtems api don't have to include it. | ||||
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 5 | -64/+66 |
* | changed version to 3.5.17 | Joel Sherrill | 1996-05-24 | 2 | -2/+2 |
* | Updated version to 3.5.15. | Joel Sherrill | 1996-05-02 | 2 | -2/+2 |
* | changed version number to 3.5.14 | Joel Sherrill | 1996-04-24 | 2 | -2/+2 |
* | modified to generate fatal error when an unconfigured directive is invoked. | Joel Sherrill | 1996-04-19 | 2 | -2/+59 |
* | Removed prototyes for static inline routines and moved the comments into | Joel Sherrill | 1996-03-06 | 4 | -106/+40 |
| | | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana. | ||||
* | Changed io manager initialization routine to not be static and added it here. | Joel Sherrill | 1996-02-21 | 1 | -0/+37 |
* | Changed io manager initialization routine to not be static. | Joel Sherrill | 1996-02-21 | 1 | -0/+8 |
* | changed io manager initialization routine to not be static | Joel Sherrill | 1996-02-21 | 2 | -6/+2 |
* | Removed the internal thread objects and dispersed its contents to | Joel Sherrill | 1996-02-21 | 1 | -12/+14 |
| | | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized. | ||||
* | idle thread now created before system initialization thread. | Joel Sherrill | 1996-02-14 | 1 | -4/+1 |
| | | | | Also system initialization thread only created in MP systems. | ||||
* | Moved some initialization from the system initialization thread to | Joel Sherrill | 1996-02-14 | 1 | -2/+42 |
| | | | | | initialize_executive_early. This was done to clear up an ordering problem in which global tasks could be created before the MPCI layer was initialized. | ||||
* | changed post task extension from user set to api set and added flag | Joel Sherrill | 1996-02-13 | 2 | -4/+0 |
| | | | | in each thread which must be set when the post switch extension is to be run. | ||||
* | *** empty log message *** | Joel Sherrill | 1996-02-12 | 1 | -4/+0 |
* | changed version to 3.5.1 | Joel Sherrill | 1996-01-19 | 2 | -2/+2 |
* | changed version | Joel Sherrill | 1995-12-08 | 2 | -2/+2 |
* | typos fixed | Joel Sherrill | 1995-10-31 | 5 | -34/+43 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 12 | -32/+32 |
* | moving files around and adding the exec/wrapup directory | Joel Sherrill | 1995-09-22 | 3 | -5/+6 |
* | More file movement required api extension to be added to score | Joel Sherrill | 1995-09-21 | 1 | -0/+3 |
* | Changed version number | Joel Sherrill | 1995-09-20 | 2 | -2/+2 |
* | Minor bug fixes to get all targets compilable and running. The | Joel Sherrill | 1995-09-19 | 2 | -8/+198 |
| | | | | | | single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs. | ||||
* | Added... This is the Configuration Tables Template file. | Joel Sherrill | 1995-09-11 | 2 | -0/+564 |
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 19 | -663/+462 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | ||||
* | Moved _Thread_Information -> _RTEMS_tasks_Information. | Joel Sherrill | 1995-08-23 | 2 | -2/+4 |
| | | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it. | ||||
* | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1995-08-23 | 8 | -18/+27 |
| | | | | | | both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. | ||||
* | + Added object type field to object id. | Joel Sherrill | 1995-08-18 | 1 | -0/+1 |
| | | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information | ||||
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 11 | -384/+391 |
| | | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | ||||
* | no limit removed | Joel Sherrill | 1995-08-17 | 2 | -2/+2 |
* | final 3.2.1 Module file and version updates | Joel Sherrill | 1995-08-15 | 2 | -2/+2 |
* | after testing go32 and cvme961 | Joel Sherrill | 1995-07-21 | 2 | -2/+2 |
