this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
are:
<corsepiu@faw.uni-ulm.de>.
PROBLEMS
can/will be fixed.
it work.
when building the executive source.
used to calculate the amount of memory used by tasks whether the
POSIX API is enabled or disabled.
