be resolved.
it was necessary to include system.h before checking if anything was
defined.
RTEMS initialization tasks.
deleted a blank line in rtemsapi.c
only the rtems api don't have to include it.
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
Also system initialization thread only created in MP systems.
initialize_executive_early. This was done to clear up an ordering problem
in which global tasks could be created before the MPCI layer was initialized.
in each thread which must be set when the post switch extension is to be run.
like signal dispatching.
