* | changed version to 19981203 | Joel Sherrill | 1998-12-04 | 2 | -2/+2 |
* | Moved stackchk.h to rtems subdirectory. | Joel Sherrill | 1998-12-03 | 2 | -2/+2 |
* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. | ||||
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 6 | -0/+43 |
| | | | | it work. | ||||
* | changed version to 4.0.0-AFCC | Joel Sherrill | 1998-10-29 | 2 | -2/+2 |
* | changed version to 4.0.0 | Joel Sherrill | 1998-10-27 | 2 | -2/+2 |
* | changed version to 4.0.0-beta4b | Joel Sherrill | 1998-10-26 | 2 | -2/+2 |
* | changed version to 4.0.0-beta4a | Joel Sherrill | 1998-10-15 | 2 | -2/+2 |
* | changed version to 4.0.0-beta4 | Joel Sherrill | 1998-10-12 | 2 | -2/+2 |
* | changed version to 981006 | Joel Sherrill | 1998-10-06 | 2 | -2/+2 |
* | changed version to 981001 | Joel Sherrill | 1998-10-01 | 2 | -2/+2 |
* | changed version to 980923 | Joel Sherrill | 1998-09-23 | 2 | -2/+2 |
* | changed version to 980921 | Joel Sherrill | 1998-09-21 | 2 | -2/+2 |
* | changed version to 980911 | Joel Sherrill | 1998-09-11 | 2 | -2/+2 |
* | changed version to 980824 | Joel Sherrill | 1998-08-24 | 2 | -2/+2 |
* | Added __RTEMS_INSIDE__ macro to insure that ".inl" files are ALWAYS included | Joel Sherrill | 1998-08-24 | 1 | -1/+1 |
| | | | | when building the executive source. | ||||
* | changed version to 980821 | Joel Sherrill | 1998-08-21 | 2 | -2/+2 |
* | Modified version number to recut snapshot. | Joel Sherrill | 1998-08-21 | 2 | -2/+2 |
* | changed version to 980820pm-BSD | Joel Sherrill | 1998-08-20 | 2 | -2/+2 |
* | changed version to 980820-BSD | Joel Sherrill | 1998-08-20 | 2 | -2/+2 |
* | changed version to 980819 | Joel Sherrill | 1998-08-19 | 2 | -2/+2 |
* | changed version to 980808 | Joel Sherrill | 1998-08-08 | 2 | -2/+2 |
* | changed version to 9800808 | Joel Sherrill | 1998-08-08 | 2 | -2/+2 |
* | changed version to 980724 | Joel Sherrill | 1998-07-24 | 2 | -2/+2 |
* | changed version to 980723 | Joel Sherrill | 1998-07-23 | 2 | -2/+2 |
* | changed version to 980710 | Joel Sherrill | 1998-07-10 | 2 | -2/+2 |
* | changed version to 980707 | Joel Sherrill | 1998-07-07 | 2 | -2/+2 |
* | changed version to 9800707 | Joel Sherrill | 1998-07-07 | 2 | -2/+2 |
* | changed version to 980618 | Joel Sherrill | 1998-06-18 | 2 | -2/+2 |
* | changed version to 980604 | Joel Sherrill | 1998-06-04 | 2 | -2/+2 |
* | changed version to 980527 | Joel Sherrill | 1998-05-27 | 2 | -2/+2 |
* | Corrected interrupt stack allocation. | Joel Sherrill | 1998-05-27 | 2 | -6/+14 |
* | changed version to 980521 | Joel Sherrill | 1998-05-21 | 2 | -2/+2 |
* | changed version to 980518 | Joel Sherrill | 1998-05-18 | 2 | -2/+2 |
* | Include memory for Ada task stacks. | Joel Sherrill | 1998-05-18 | 2 | -4/+4 |
* | Added default value for CONFIGURE_MAXIMUM_POSIX_THREADS since it is | Joel Sherrill | 1998-05-04 | 2 | -0/+2 |
| | | | | | used to calculate the amount of memory used by tasks whether the POSIX API is enabled or disabled. | ||||
* | Removed redundant "* 1024" which exploded the size of the workspace. | Joel Sherrill | 1998-04-30 | 2 | -4/+4 |
* | Added numerous entries to make the memory calculation more accurate: | Joel Sherrill | 1998-04-27 | 2 | -2/+134 |
| | | | | | | | | | | | | | + POSIX threads + Ada tasks + POSIX threads API support + POSIX condition variables + POSIX keys (still do not account for data fields) + POSIX mutexes + POSIX queued signals + added macro for extra memory for task stacks + default value for CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + extra memory for Ada task stacks | ||||
* | Changed to account for libio's maximum_semaphores as well as its | Joel Sherrill | 1998-04-18 | 2 | -2/+10 |
| | | | | | | memory requirements. Also added variable to tell libio how many file descriptors to allocate. | ||||
* | Changed version number so script will work. | Joel Sherrill | 1998-04-18 | 2 | -2/+2 |
* | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 1998-04-15 | 2 | -2/+18 |
| | | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | ||||
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 5 | -10/+57 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | changed version to ralf-980414 | Joel Sherrill | 1998-04-14 | 2 | -2/+2 |
* | Account for interrupt stack space | Joel Sherrill | 1998-04-14 | 2 | -2/+24 |
* | Added stack checker extension | Joel Sherrill | 1998-04-14 | 2 | -4/+28 |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 2 | -8/+32 |
| | | | | by newlib. | ||||
* | changed version to 4.0.0-beta2 | Joel Sherrill | 1998-03-31 | 2 | -2/+2 |
* | changed version to 4.0.0-beta1 | Joel Sherrill | 1998-03-24 | 2 | -2/+2 |
* | Added misisng line continuation. | Joel Sherrill | 1998-02-20 | 2 | -2/+2 |
