path: root/c/src/exec/sapi (follow)
* 2001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-022-13/+18
| | | | | * Per PR126, configuration structures now match docs. * include/rtems/config.h: Use public data types.
* 2001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-282-6/+29
| | | | | | | * PR132 requested some tinkering ot lower memory. * include/confdefs.h: Lowered footprint of device driver table and statically configure user extensions. Now if no static extensions are configured, then the table is not instantiated.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-286-5/+8
| | | | | | | | * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-03-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-156-120/+186
| | | | | | | * src/extension.c: Split to reduce minimum code size per PR134. * src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c: New files. src/Makefile.am: Modified to reflect above.
* 2002-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-075-273/+6
| | | | | | * optman/, optman/.cvsignore, optman/Makefile.am, optman/no-ext.c, optman/no-io.c: Removed entire contents of optman/ directory since it has been moved.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-1/+1
| | | | | | | | | | | | | | | | * configure.ac: Use AS_IF instead of if/then/else. Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix. Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix. Add include/Makefile to CONFIG_FILES. Add AC_ENABLE_MULITLIB. Remove wrapup/rtems, wrapup/itron, wrapup/posix. Remove */optman/Makefile from CONFIG_FILES. * Makefile.am: Add include to SUBDIRS. * rtems/Makefile.am: Remove optman from SUBDIRS. * sapi/Makefile.am: Remove optman from SUBDIRS. * include/Makefile.am: New file. * include/rtems/bspIo.h: Relocated from lib/include. * include/rtems/libio_.h: Relocated from lib/include.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-193-4/+9
| | | | | * optman/Makefile.am: Add multilib support. * src/Makefile.am: Add multilib support.
* 2001-10-16 Chris Johns <ccj@acm.org>Joel Sherrill2001-10-167-9/+197
| | | | | | | | * include/confdefs.h, include/rtems/config.h, include/rtems/io.h, optman/no-io.c, src/exinit.c, src/io.c: Added a device driver register/unregister interface to allow device drivers to be installed and removed at runtime. This means you do not need devices present in the device table when you build.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-168-88/+63
| | | | | | | | | * include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5. * inline/rtems/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs, require automake-1.5. * macros/rtems/Makefile.am: Remove. * Makefile.am: require automake-1.5.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-122-1/+4
| | | | * include/rtems/directives.h: Fixed typo.
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-285-4/+11
| | | | | | | * include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-2/+7
| | | | * optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5.
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-162-0/+11
| | | | * include/confdefs.h: Fix real-time clock support.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-055-15/+22
| | | | | | * include/Makefile.am, include/rtems/Makefile.am, inline/rtems/Makefile.am, macros/rtems/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-292-2/+8
| | | | | * include/confdefs.h: define CONFIGURE_NEWLIB_EXTENSION 0 if not using NEWLIB, cleanup related comment.
* 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-262-3/+14
| | | | * include/confdefs.h: include cpuopts.h, replace stubdr w/ devnull.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-312-1/+9
| | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * include/confdefs.h: Replaced include of <sys/siginfo.h> with <signal.h> since that file no longer exists.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-0/+6
| | | | | * include/confdefs.h: Set CONFIGURE_INIT_TASK_STACK_SIZE to 0 if there is no Classic API Initialization Tasks Table defined.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-5/+29
| | | | | | * include/confdefs.h: Modified code that accounts for initialization task/threads with greater than minimum stack sizes so it would compile even if optional APIs are disabled.
* 2000-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-122-0/+11
| | | | | * include/confdefs.h: Account for initialization tasks and threads which use larger than minimum stack sizes.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-283-12/+18
| | | | | | * include/rtems/io.h (rtems_driver_address_table): Added "_entry" to all names. * src/io.c: Accounted for above.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-053-0/+6
| | | | * src/Makefile.am, optman/Makefile.am: Include compile.am.
* Patch from Eric Valette <valette@crf.canon.fr> and Yacine El KolliJoel Sherrill2000-07-061-2/+2
| | | | <elkolli@crf.canon.fr> to add support for the mbx860_005b.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-128-89/+149
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-139-0/+19
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-1/+0
* Patch rtems-rc-19991203-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-211-13/+8
| | | | | | | | | | | which fixes a nasty dependency bug in optman/Makefile.am. Those directories have been build twice before, i.e. re-running make after having built rtems before, was rebuilding the files in optman/ directories. To apply: patch -p1 < rtems-rc-19991203-6.diff ./bootstrap
* Patch rtems-rc-19991117-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-231-1/+1
| | | | | | | * the PACKHEX etc problem * prevents the *.rels being removed inside the build-tree * a typo which only shows for when MP is activated * Alters some custom/*cfg files
* Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-235-110/+68
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-224-24/+24
* Updated copyright notice.Joel Sherrill1999-11-1721-42/+21
* Fixed so can be included multiple times in the executive source.Joel Sherrill1999-11-161-0/+9
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-095-8/+348
| | | | for RTEMS.
* Fixed warning where initialized default POSIX API structure didJoel Sherrill1999-11-091-0/+2
| | | | have have semaphores and message queue fields.
* Fixed typo.Joel Sherrill1999-11-051-3/+3
* This is another pass at making sure that nothing outside the BSPJoel Sherrill1999-11-052-0/+5
| | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* The files in libcpu should not be directly dependent on any BSP. InJoel Sherrill1999-11-041-0/+46
| | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated.
* Added CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM as a configurationJoel Sherrill1999-11-031-4/+3
| | | | parameter.
* Added message queues and semaphores.Joel Sherrill1999-11-021-0/+11
* Added CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES andJoel Sherrill1999-11-021-0/+24
| | | | CONFIGURE_MAXIMUM_POSIX_SEMAPHORES.
* Enabled configuring mini or full IMFS.Joel Sherrill1999-11-011-0/+29
* Renamed CONFIGURE_POSIX_INIT_TASK_STACK_SIZE toJoel Sherrill1999-10-211-6/+6
| | | | CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE because in POSIX they are threads.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-047-21/+21
* Removed Makefile.in generated from Makefile.amJoel Sherrill1999-10-047-2263/+0
* Regenerated.Joel Sherrill1999-10-047-35/+42
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-0714-133/+2274
* Removed by patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-071-49/+0
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-07-301-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The main topic is replacing the hard-coded values for HAS_MP and HAS_RDBG in custom/*.cfg with per-bsp configuration-time autoconf checks (This is the patch I had mentioned before earlier this week). CHANGES * HAS_MP removed from custom/*.cfg, replaced with configuration time autoconf check * HAS_RDBG removed from custom/*.cfg, replaced with configuration-time autoconf check * NEW: c/src/make/bsp.cfg.in, takes configuration-time checked per-bsp values (i.e. HAS_MP, HAS_RDBG), gets installed as $(prefix)/<bsp>/make/bsp.cfg * NEW: default.cfg includes bsp.cfg - this change is backward compatible. * IMPORT_SRC: apply VPATH instead for ts_386ex/i386ex subdirectory Makefile.ins * HACK: a bug in acpolish mis-handles addtions to makefile variables which are enclosed in gmake conditionals: c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in * Apply inline_dir, HAS_MP and HAS_RDBG for avoiding configuration of unneeded subdirectories in various configure.in files. * Several minor changes in Makefile.ins and configure.ins, wrt. to the order of including *.cfg and defining Makefile variables APPLYING THE PATCH: patch -p1 < rtems-rc-19990709-4.diff ./autogen
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-07-261-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This patch is an addition to "The big-patch" CHANGES: * FIX: c/Makefile.am: bogus comment which changed the behavior of c/Makefile.am removed * FIX: make/custom/ts_i386ex.cfg did not set HAS_NETWORKING correctly (Me thinks it might have been me who added this bogus setting :-). * NEW: removing make targets get, protos, debug_install, profile_install * NEW: replacing clobber with distclean * NEW: Reimplement distclean and clean as reverse depth first make targets (adaptation to automake's behavior) * NEW: removing RCS_CLEAN from make distclean (tools/build/rcs_clean is still in - remove it?) * NEW: "$(RM) Makefile" added to make distclean (adaptation to automake's behavior) * NEW: "$(RM) config.cache config.log" to CLOBBER_ADDITIONS in [lib|exec|tests]/Makefile.in (adaptation to automake's behavior) * NEW: "$(CLEAN_PROTOS)" removed (Not used anywhere) * NEW: binpatch.c moved from i386 bsp tools to tools/build (AFAIS, binpatch is not specific to the pc386 BSP at all) * NEW: AC_EXEEXT added to all configure scripts which contain AC_PROG_CC (Cygwin support) * NEW/Experimental: An experimental implementation of temporary installation tree support in libbsp/i386/pc386/tools/Makefile.am, based on dependency tracking with make, instead of applying INSTALL_CHANGE. REMARK: * This patch is small in size, but changes the behavior of "make clean|distclean|clobber" basically. * This patch does not alter building/compiling RTEMS, ie. there should be no need to rerun all "make all" building tests. KNOWN BUGS: * make RTEMS_BSP="..." distclean in c/ runs "make distclean" in BSPs subdirectories passed through RTEMS_BSP and in "c/." only, but does not descend into other BSP subdirectories previously configured with different settings of make RTEMS_BSP="...". => Workaround: always use the same setting of RTEMS_BSP when working inside the build-tree. * "make [distclean|clean]" do not clean subdirectories, which have been configured at configuration time, but which are not used due to make-time configuration (e.g. macros/networking/rdgb subdirectories). This will problem will vanish by itself when migrating from make-time to configuration-time configuration APPLYING THE PATCH mv c/src/lib/libbsp/i386/pc386/tools/binpatch.c tools/build patch -p1 < rtems-rc-19990709-2.diff autogen
