path: root/c/src/exec/sapi/optman (follow)
* modified to generate fatal error when an unconfigured directive is invoked.Joel Sherrill1996-04-192-2/+59
* Changed io manager initialization routine to not be static.Joel Sherrill1996-02-211-0/+8
* posix support initially addedJoel Sherrill1995-09-262-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-15/+18
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+2
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-23/+23
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Initial revisionJoel Sherrill1995-05-112-0/+144
