* include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/Makefile.am, include/rtems/Makefile.am,
inline/rtems/Makefile.am, macros/rtems/Makefile.am:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
