* include/Makefile.am, include/rtems/Makefile.am,
inline/rtems/Makefile.am, macros/rtems/Makefile.am:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
