path: root/c/src/exec/sapi/include (follow)
* Removed prototyes for static inline routines and moved the comments intoJoel Sherrill1996-03-061-53/+2
| | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana.
* changed io manager initialization routine to not be staticJoel Sherrill1996-02-211-3/+1
* changed post task extension from user set to api set and added flagJoel Sherrill1996-02-131-2/+0
| | | | in each thread which must be set when the post switch extension is to be run.
* changed version to 3.5.1Joel Sherrill1996-01-191-1/+1
* changed versionJoel Sherrill1995-12-081-1/+1
* typos fixedJoel Sherrill1995-10-312-12/+12
* posix support initially addedJoel Sherrill1995-09-263-5/+5
* moving files around and adding the exec/wrapup directoryJoel Sherrill1995-09-221-1/+1
* Changed version numberJoel Sherrill1995-09-201-1/+1
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-4/+99
* Added... This is the Configuration Tables Template file.Joel Sherrill1995-09-111-0/+282
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-116-265/+125
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-233-3/+6
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-174-107/+122
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* no limit removedJoel Sherrill1995-08-171-1/+1
* final 3.2.1 Module file and version updatesJoel Sherrill1995-08-151-1/+1
* after testing go32 and cvme961Joel Sherrill1995-07-211-1/+1
* Ada95, gnat, go32Joel Sherrill1995-07-121-1/+1
* changed release number to 3.2.0Joel Sherrill1995-06-041-1/+1
* Fully tested on all in-house targetsJoel Sherrill1995-05-242-4/+4
* Initial revisionJoel Sherrill1995-05-118-0/+1121
